- Select IKE.
- Select Globals tab.
- In CertIdentitySubjectName, type the digital certificate subject name use as identity certificate.
- Select Apply.
Globals Field Definitions
Use the data in the following table to use the Globals tab.
Name | Description |
CertIdentitySubjectName |
Specifies the digital certificate subject name use as identity certificate in IKE. |
